05-14-2016 01:47 AM
When the solution given by Canon Online Manual for Error 1003 did not succeed qwith multiple tries, I pulled the power cord, drained the power by holding down the on button for 15 secs. X 3 then replaced power cord and tried to print again. 3rd of these routines succeeded!
11-07-2016 09:16 PM
Thank you very much! Your idea worked. I've had this MG6820 for less than a year- I do print quite a bit but yikes! with a whole lot of ink bought, I was kind of freaking out that it would not work. I tried fixing the 1003, as you mentioned quite a few times to no avail but then followed your directions.
OT-----I have noticed just recently that the printer wasn't printing out the entire page from my web site-lines of type were missing. What could be happening? Any idea?
Thank you very much again.
11-07-2016 09:16 PM
03-15-2019 02:50 PM
Hi CSmith1,
So we can best assist you, we would need some more information to help narrow down this issue.
01-04-2017 10:48 PM
Unbelieveable! Don't know how you figured this out, but it worked. You saved my sanity and my printer. Thank you.
01-05-2018 06:17 AM
canon error 1003 solution
Press the HOME button, select Setup, Device settings, and Print settings in this order, and then set Prevent paper double-feed to ON.
other
Press the HOME button, select Setup, Device settings, and then select cassette incorrect paper detection to No
this will solver error 1003
