05-29-2016 04:43 PM
When I try to install Solution Menu EX 1.4.1 on iMac 10.11.5, it says there is a later version already installed, and won't install. I don't have a later version. How to get Solution Menu EX to install on MacOS El Capitan?
06-01-2016 12:40 AM
Hi kwinieck,
I would like to have you reset the printing system on your Mac, then reinstall the drivers and software to see if this will resolve the issue. To reset the printing system, please follow these steps:
1. Choose Apple menu > System Preferences, then click Printers & Scanners.
2. Hold down the Control key as you click in the list at the left, then choose “Reset printing system” from the menu that appears. After you reset the printing system, the list of printers in Printers & Scanners preferences should be empty. If your printer is still listed on the left select your printer and then click the minus (-) button to delete it.
3. Restart your Mac.
Next, we will want to download the latest drivers from the Canon USA website. Please click here to go to the PIXMA MG8120 Drivers and Downloads page. Once on the initial download page for your model, please do the following:
1. Verify that the operating system detected in the "OPERATING SYSTEM" field is correct, and if it is not, please click the drop-down menu to select your operating system. Please note that you may need to scroll up or down in the list to select your operating system.
2. Next, below the red box labeled "DRIVERS", locate the CUPS file, then click the SELECT button to the right of the filename. When you do, a dark gray DOWNLOAD button will appear; below that, a checkbox will be shown asking you to agree to the terms of the disclaimer to continue with the download. Please click in that checkbox to agree to the terms. When you do, the dark gray DOWNLOAD button will turn red. Please click on the now red DOWNLOAD button; the file will start downloading. The time for the download process may vary depending on the speed of your Internet connection and the size of the file being downloaded.
Once you have downloaded the CUPS driver file from the website, please also download all other items from the DRIVERS and SOFTWARE sections of the webpage.
Once all items have been downloaded, please double-click on each of the items on your Mac to install them, starting with the CUPS drivers file. If you are connecting the printer wirelessly, please be sure to install the Canon IJ Network Tool last after all other items have been installed; if you are connecting the printer via USB cable, the Canon IJ Network Tool does not need to be installed. Once all items have been reinstalled, please restart your Mac.
If you still run into difficulty after following the above recommendations, we ask that you please call 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays) for further assistance. A Canon technical support representative will be happy to help. There is no charge for this call.
05-31-2016 11:56 AM
Hi kwinieck,
What is the model number of the Canon product that you own?
05-31-2016 01:51 PM
05-31-2016 03:46 PM
Hi kwinieck,
Not all printers are compatible with operating systems, but the PIXMA MG8120 is compatible with Macintosh OSX 10.11 El Capitan. Let's start by making sure that you have the most current drivers.
Click HERE.
Scroll down to "Drivers" next to "Recommended Downloads."
Click "Select" next to "MG8100 series CUPS Printer Driver."
Accept the Terms of Service by clicking the checkbox.
Press "Download."
Open and run the file.
Follow the onscreen instructions to complete the installation.
Repeat these steps for the other drivers.
This didn't answer your question or issue? Please call or email us at one of the methods on the Contact Us page for further assistance.
05-31-2016 07:05 PM
I installed the 3 drivers. Then tried installing Solution Menu EX, and still get "Solution Menu EX can't be installed on this disk [Macintosh HD]. A newer version of this software alread exists on this disk." The file I'm installing is msmx-mac-1_4_1-ea11.dmg.
05-31-2016 07:51 PM
Hi kwinieck,
The file listed is for Macintosh OSX 10.10 Yosemite or earlier. It does not appear to be available for OSX 10.11. You might try installing the Quick Menu instead, which is supported by OSX 10.11.
05-31-2016 08:04 PM
I installed Quick Menu, but it shows mostly blank rows. The Web Services row shows 5 icons, but all the other rows, e.g., Scan, Manual & Device Information, are empty.
06-01-2016 12:40 AM
Hi kwinieck,
06-01-2016 10:06 AM
Thank you.
You left out the last step for wireless connection: Select System Preferences / Printers & Scanners; wait until it detects the wireless Canon MG8120; add Canon MG8100 series (scanner); select Canon MG8100 series; add Canon MG8100 series_19BE5DC9DB88 (printer). After that, Canon Quick Menu shows all except Manual & Device Information.
Canon Quick Menu is peculiar for an Apple application in that the "Exit" button is on the lower-right and is labeled X. I would expect a red button on the upper-left, and/or a Quit button at the lower-right. And the small shortcut menu at the lower-right of the desktop has no "exit" button (must go to the Canon Quick Menu at upper-left in the desktop toolbar and select Quit Quick Menu).
But at least the Canon Quick Menu now works. Thanks again.
01-29-2018 10:43 PM
@ Kwinieck
I am have the exact same problem, just can't get the last componet. I have been trying for two day ow....I give up!! Unless you've fugired it out
