10-12-2017 09:54 AM
I have a Pixma MX922 and I am trying to scan to a USB drive. When I plug the USB flash drive into the printer, the printer says "USB drive detected". So I set up the Scan to USB flash drive function. But when I scan I receive an error message "Cannot detect a USB flash drive". Doesn't matter if I scan from the feeder or the screen.
Any suggestions?
01-09-2018 02:03 PM
I have a SanDisk 64GB from several years ago. It appears to correspond most closely to this one on SanDisk's web site:
https://www.sandisk.com/home/usb-flash/cruzer-glide
I also have a MicroCenter 128GB that you can find here:
http://www.microcenter.com/product/486104/128GB_SuperSpeed_USB_30_Flash_Drive
Good luck.
12-22-2017 03:33 PM
Hi timevans7057540,
I'm afraid the port on the front of the MX922 is not a USB port, but is meant for printing from PictBridge enabled cameras. A USB drive will fit, but will not be recognized as a destination. I regret any inconvenience.
This didn't answer your question or issue? Please call or email us at one of the methods on the Contact Us page for further assistance.
01-01-2018 06:24 PM
Well, perhaps BillS is not the product expert he thought he was. (Sorry, Bill, but try not to be afraid about the machine.) The port on the front is a USB port and will accept scans. That said, the printer is **bleep** particular about USB drives; it will not recognize many of them, but it does recognize some. I've been scanning to USBs on my 922 for some years now.
01-09-2018 12:00 PM
Thanks for the reply. Any advice on which type of USB drives to use?
01-09-2018 02:03 PM
Good luck.
03-17-2018 03:42 AM
04-29-2020 02:19 AM - edited 04-29-2020 02:25 AM
To WTig3ner: Seeing your encouraging post, I went through eight USB drives and the printer would scan to none of them (even after saying "a USB drive is connected")! Last resort: tried a USB card reader -- same shape as a thumb drive, but with side slots for SDXC and MicroSD cards. Plugged in a Kingston 16G MicroSD card, and it worked perfectly. It was so much easier to use the document feeder on the 922 than page-at-a-time scans with my flatbed scanner. Thanks for correcting the erroneous info from BillS -- after his entry, I almost clicked away without reading any further!
11-25-2020 12:13 PM
All,
I too was having this issue. I plugged several different types of USB drives in and got the same results of "you've got a drive inserted, but you don't have a drive inserted."
First time I tried, i plugged the USB drive in, then started the scanning process, selected the USB storage option and then when I got the error, I inserted many different drives, all saying what you've all seen.
Here's where it gets a little wierd: In frustration, I decided to follow the typical "power off and retry" option. So I pulled the USB out, then powered down the printer. Here's the steps that follow what I did:
So what worked for me in USB drives?
Perhaps this isn't an an issue with compatibility as more an issue of following steps in a certain order. I'd be curious if anyone can replicate this as I've described.
Michael
03-31-2020 12:30 PM - edited 03-31-2020 12:30 PM
I have a Pixma MX922 and use the Canon IJ Scan Utility for scanning to my Mac. I don't have problems scanning the first document. After I choose 'Exit' to save the scan and want to scan another document, the app becomes unresponsive. I have to quit out of it and then re-open to scan the next document. I've tried to download recent & recommended drivers but it hasn't helped. Anyone else had this issue and find a solution? Thanks.
04-01-2020 04:37 PM
Hi RidleyNY.
That problem sounds like an issue that occurred for some users when OS 10.15 first launched. Try the following:
