11-01-2019 12:49 PM - edited 11-01-2019 12:55 PM
I have a PIXMA MG8120 and with the MP and XPS drivers installed properly I am still not able to scan or print.
When I use the controls on the actual printer itself I select "Autoscan" and it returns "Processing... Please wait momentarily"
It then just returns to the previous screen as though I had not told it to do anything. Is there some software interface I am meant to use instead of the controls on the device?
I am running Windows 10 pro.
11-06-2019 03:33 PM
Hi Heelaque.
Please click the link below to download and install the MP Navigator EX software by clicking the link below:
11-06-2019 03:33 PM
Hi Heelaque.
11-08-2019 12:07 PM - edited 11-11-2019 01:46 PM
I was able to download and install the software with no problem but when I try to scan I get an error:
"Internal Error occurred. Scanner driver will be closed".
"Code:5,202,54"
EDIT: I restarted my system and it now works as expected, thank you.
11-14-2019 03:20 PM
Hello.
Try uninstalling the MP Navigator, the MG8100 series MP Drivers and the Canon IJ Network Tool (if the printer is being used wirelessly). Once these are removed, return to our website to reinstall the MP Drivers and the MP Navigator. Temporarily disable any firewall or anti-spyware programs before attempting to reinstall to see if this helps.
