09-28-2015 05:29 PM
Where exactly can I adjust the paper size settings etc. when trying to print a photo on a Pixma MG 5420 from an iMac Intel running Yosemite?
And is it mandatory to use Image Garden?
09-30-2015 08:59 AM
Hi purbrookian,
It is not mandatory to use My Image Garden. The paper size and other settings would be changed within the program that you are using.
In the Page Setup Dialog, you configure the basic print settings such as the size of paper loaded in the machine or the scaling ratio.
To open the Page Setup dialog, you typically select Page Setup... from the File menu of your application software.
Click the pop-up menu, and then select the following items:
Set the paper size or scaled printing.
Save as DefaultYou can save the attributes of the displayed page as the default settings.
Select the model to be used for printing.
Paper SizeSelect the size of the paper to be used for printing. To set a non-standard size, select Manage Custom Sizes....
OrientationSelect the print orientation.
ScaleSet the scaling percentage. You can expand or reduce the size of the document when printing.
