06-08-2017 06:55 PM
06-09-2017 02:04 AM
Hi Rsmith0399,
There is a program that can be used with the printer called Easy-PhotoPrint that Canon developed to easily print quality photos from the printer. Printing from this program should resolve the issue being experienced. If you do not have the program installed on your computer, it can be downloaded from the Canon USA website free of charge here. You will find the program under the SOFTWARE section of the page.
Once the program is installed, please follow these steps to print:
1. Open Easy-PhotoPrint.
2. Inside of the Canon Utilities folder, you should see a folder for EASY-PHOTOPRINT. Inside of that folder, you should see a program for EASY-PHOTOPRINT; please click on that to launch the application.
3. Once inside of the application, you will see a folder structure on the left-hand side where you can select a photo or image. Please navigate to the location of the photo/image you would like to print. When you do, all available images in that location should appear in the right pane of the window. Please note: If a screen appears with options to Photo-Print, Create an Album, Sticker Print, etc., please select the PHOTO-PRINT option to view the area with the folder structure.
4. Underneath each of the photos appearing in the right pane of the window, you will see an up and down arrow, as well as a "0". Please click the UP arrow once underneath the image you would like to select, then click the PAPER SELECTION tab at the top of the window.
5. On the PAPER SELECTION TAB, please select the PRINTER, PAPER SOURCE, PAPER SIZE, and MEDIA TYPE, then click the LAYOUT/PRINT tab at the top of the window.
6. Please select the desired layout from the left-hand pane of the window. When you do, a preview of what the image should look like when printed will appear in the right-hand pane of the window.
7. Once you have selected a layout, please click the PRINT button. The photo/image should print.
Hope this helps! Should you still experience difficulty, we ask that you please contact a Canon technical support representative here for further assistance. A representative will be happy to assist you free of charge.
06-09-2017 10:55 AM
06-09-2017 01:16 PM
