Reply
New Contributor
Pixma 495 via USB, NOT WiFi
Can't get my Pixma495 to set up by USB port with the correct cable. I no longer have internet (use phone hotspot) and need to use the cable. Help!
Highlighted
Re: Pixma 495 via USB, NOT WiFi
Hi the4jimmies,
It is unclear if you are setting the MP495 up with a version of Windows or Mac operating system. You will find recommendations for both systems below:
Windows OS
Make sure the printer is on and not displaying an error message.
Make sure the USB cable is disconnected.
Remove the printer from the list of printers.
Restart the computer.
If you have the setup disc that came with the printer, install it into the computer and reinstall the driver.
Connect the USB cable when instructed to do so.
If you do not have the setup disc connect the USB cable and add the printer through Devices & Printer.
Perform a test print.
Mac OS
Remove the printer from the list of Printer & Scanner.
Connect the USB cable.
Confirm the printer is added back to the Printer & Scanner list.
New Contributor
Got free used Lexmark. Finally went to "Free Download" site ok'd by Norton and downloaded original info for this lexmark and everything worked fine via usb. Ran virus software after and nothing was found. Figurin needed another download for this Canon product?
powered by Lithium
