Reply
New Contributor
PIXMA TS9120 keeps going offline
My TS9120 keeps going offline after it's idle and then it doesn't come back on when I send a job to print.  I've tried reinstalling it, tried wireless as well as LAN connections.  Sometimes restarting the printer works, sometimes it doesn't.   Any ideas???
Respected Contributor
Re: PIXMA TS9120 keeps going offline
I would start by giving the printer a static IP address.
Printer sleeps, gets turned off, etc, it will always get the same IP, and you will always be able to identify or find it on your network.  This will help with any troubleshooting as well.
Rick
~6D2 (f/w 1.0.4) ~16-35mm f2.8L II, 50 f1.8 STM, 85 prime USM, 70-200 f2.8L IS II ~70-300 USM II ~Sigma 24-70 f2.8 Art (f/w 2.02)
~Sigma 150-600 C + TC1401 1.4x (f/w 2.00) ~Speedlite 430 EX II ~DxO PhotoLab Elite ~Windows10 Pro1903 ~EVGA RTX 2080 FTW3 Ultra
New Contributor
I finally called Canon Tech Support.  Printer is actually online, but the Mac isn't seeing it.  Solution seems to be to toggle the WI-FI off and then back on.  The printer then shows up as online again.  Kind of a work-around, but easier than anything else I've tried previously.
My recommendation is a solution.  A static IP will resolve this issue
Tech support gave you a "work around"
Deal with it once, or deal with it everytime you want to print.
Your choice.
Rick
New Contributor
Hi Rick,
I don't know how to give my printer a static IP.  I'll do some research on that.
The "work around" is NOT working anyway.  Logging OFF of my wi-fi and then logging back ON worked a couple of times, but not reliably.  I'm almost ready to dump this printer and try something else.
New Contributor
Same problem on my TS9120. I would appreciate hearing how to set up the static IP address... if that's the solution. BTW does having a VPN (Surfeasy) affect this IP address issue?
Hi bilg,
If your computer is connected to a vpn then yes it will cause a issue. The computer will be on the virtual private network and the printer would not. The best work around for that situation if the printer is next to the computer is to use a printer usb cord. If not, the printer would need to be on the same network as the computer.
Now if the printer and computer are on the same network, I recommend disabling the ipv6 setting on the printer. Please click HERE for the steps.
If you would like to speak with someone in real time about this issue, you can also call the Canon support team for free  at 1-800-OK-CANON (1-800-652-2666), Monday - Friday, 8:00 AM - 8:00 PM EST.
Highlighted
New Contributor
1. If I connect using the USB (printer to desktop computer) will that affect my laptop's wireless access to the printer? 2. And is disabling the ipv6 setting part of the suggestion to connect via USB? If not, can you briefly explain why that setting maybe causing an issue - is it related to the VPN also. Thanks for your help.
powered by Lithium
