07-08-2017 01:20 PM
07-08-2017 03:34 PM
12-01-2020 09:21 AM
I purchased a used HP all - in - one for $114 from Amazon last night around 11:30 pm. B200 error and blank pages are gone!
Good luck everyone.
12-01-2020 02:44 PM
I had the same experience about 2 years ago, except I went for a new MX922 for $80 (about printhead cost). (Now MX922 is "legacy," $200 and up at Amazon.) Saved the paper and printable-CD trays, but was sad to toss the otherwise-intact dead one on the recyclables cart. Maybe using rotgut 3rd-party ink killed it, but I saved enough to just buy a new printer (several times), even at today's inflated price.
03-03-2021 12:41 AM
03-11-2021 05:25 PM
The B200 has been a big pain for a few years.I find If I just turn off the printer for a few days and it will work when I turn it back on. I also have a brother laser printer so I can wait it out.
03-20-2021 10:39 PM
03-11-2021 07:56 PM
03-12-2021 09:44 AM - edited 03-12-2021 09:45 AM
That's amazing your printer still works with the error message. Mine won't do a thing until the message is cleared out.
03-14-2021 01:53 AM
If it doesn't work and all the software is up to date there is nothing wroung with using a good screwdriver set and taking it apart, reassembling it or whatever. careful not to stip screw heads. not much to break anything worse that B200.
11-29-2021 01:47 PM
05-04-2022 10:48 AM
I had a stubborn B20 error on my MX922 for a while. I hadn’t used it in a couple of months, although i hadn’t planned on that and hadn’t taken the cartridges out and stored them. I put in new ones, but no joy. Research led me to suspect the print head was gummed up, so after an alcohol soak didn’t fix the Error i bought a solvent “kit” online; that didn’t resolve it either. I shopped online for another print head. The prices varied wildly. It felt like i was taking a chance when I chose a new one for $30 (not a manufacturer’s item). I installed the print head and reinstalled the new cartridges, which I’d sealed in a baggie to prevent their drying out. Next step: reset the MX922 using others’ advice to press/hold Stop for a couple of seconds, then press Start while immediately pressing Stop 5 times. The screen lit, then the printer took some time before ‘booting’, apparently deciding whether to accept the new print head and re-evaluate he B200 error. After 20 or 30 seconds the LED panel lit without a B200 Error warning. It came on line perfectly. It had worked
