07-08-2017 01:20 PM
07-08-2017 03:34 PM
07-04-2018 12:30 PM
Thanks, I did try this and it did clear the error but when I tried to do anything else it went back to error mode. I'll probably try the clean manually. I was going to try a deep cleaning but I could get that far.
08-01-2018 04:44 PM
This worked for me too.
Thanks a lot.
11-06-2018 08:53 AM
debillkeefe- Thank you! Had to perform it twice, but it worked the second time and I am back to normal printing. Sticky cartridges!!
11-10-2018 04:23 PM
01-20-2019 11:20 AM
This worked for me too but the directions were ambiguous; It states "Wait for print carriage to start moving to the left and..."
The carriage doesn't really go to the left. It goes to the right and back to the center. So, waiting for it to go left, it stopped. I decided to just close the cover at that point and after the printer wasted a bunch of ink, it worked again.
Thanks!
03-25-2019 11:47 AM
This also worked for me.
05-07-2019 09:56 PM
06-28-2019 06:46 AM
Thanks. It worked for me, however had to give three tries.
08-08-2019 03:07 PM
This is my second Canon with this problem. First was a Pixma MX870 now my MX922. I got a lot of use from the 870 so I accepted it was done. Buying a print head for $90 didn’t make sense because I bought it for $85 on sale. Now my MX922 was not used for 1/3 the print jobs of the 870 and I got the b200 for the second time. I cleaned it over night put it back and got couldn’t recognize the ink cartridge code. I switched to grayscale and it prints. Bought new ink today and b200 is back.
Removed head put back ink and grayscale and it works. I don’t think I have much time left.
09-20-2019 04:14 PM - edited 12-09-2019 06:04 PM
Wow, I don't know how you figured this out but it worked for me. Frankly, I don't care if it only lasts a week or so, I'm just amazed it worked! Kudos to you!!!
Edit required -- Even with the error cleared, every time I tried to print, the error reappeared. I cleared the B200 error at least five times but was never able to print anything as the error immediately reoccurred without anything being printed.
