07-08-2017 01:20 PM
07-08-2017 03:34 PM
04-05-2018 02:56 PM
@baziotowrote:llll
My experience
Step by step the printer came to life and printed at its best… OUAOU…
If this was helpful you will know by repeating it…
NOTE: DON’T RASH to throw the printer out and never agree with some idiots who advise you that the B200 Code shows the printer is basically unreparable or too costly to repair…
I repeated bazioto's steps (except skipped the water wash - if alcohol didn't open the nozzles, water wouldn't do much more).
I also got another B200 when restarting, but to speed up the step-by-step part...:
...unplugged the AC for 60 seconds.
...use the cover-open trick again to keep control at startup
...from the front panel, select MENU/Maintenance/Print Nozzle Check Pattern
It worked! The nozzle check sheet printed, and operations are back to normal.
Yes, a little patience can pay off. If you're lucky.
03-03-2019 02:09 PM - edited 03-03-2019 02:11 PM
Having encountered the dreaded B200 error code on my Canon MX922, I ran through the various proposed steps discussed here, including removing and cleaning the print head, and resetting the print head with the (print head) cover open. I still received the B200 error code. However, once I turned the printer off and manually moved the print head to the center position (i.e., from the side position it normally ends in) (see https://www.youtube.com/watch?v=r8cdisDr5Zw for a demonstration of this manual resetting; I know it's a different Canon printer, it's still the same technique), and then restarted the printer, and then ran a Maintenance/Check Nozzle just to make sure there wasn't still an issue with some sort of clog, the error cleared, and I've been able to print normally.
One problem with having had no success with either the "open cover" method or the "manually clean print head" technique, but having success after the "manual movement of print head" technique, is that I can't definitively say if it was only the "manual movement" that fixed the B200 error, or rather some combination of the three techinques. Anyway, as long as it's back to printing.
Thanks to all for the help.
DJ
07-23-2018 10:05 PM
07-28-2018 03:33 PM
This worked for me just now, when I was having the problem with the B200 code on my PIXMA M22.
07-28-2018 04:55 PM
I did all this several times and yes the b200 seems to clear but I can't print anything without the error code B200 coming back. I was able to clean the head on the low cleaning cycle but not the deep and it still never worked.
08-05-2018 05:23 PM
You know, it is amazing how my machine works perfectly just seconds before (and for weeks prior) and suddenly, this just stops working out of the blue... In fact I find it incredible as in in-credible.
This not the first time on a canon printer product and on a different model, again, the thing was working perfectly and then three minutes later I can't print anything (always at the most inconvenient time)
Is this the Canon business model?
If, so, I will not support this.
08-05-2018 05:27 PM
PS, the last time, Canon replaced my old model with a different printer under warranty exchange.
Of course, it used a different ink tank model so my investment in Canon Genuine ink tanks was a stupid move on my part too.
I am not happy with my canon printer choice 😞
10-22-2018 05:35 PM
yes this is the Business Model of maost all printer makers. I have found you tube sources though that will help replace the ink cartriges with new chips that will let them work. go to amazon and look it up
02-23-2021 10:36 AM
Well, you know, as in all things, it works until it doesn't ........ that's life.
10-22-2018 11:50 AM
