01-15-2020 12:19 PM
My PIXMA MX492 does not scan multiple pages now using the document feeder. It worked before but now I only can use the surface only. It also does not allow multiple pages to scan using the Canon IJ scan utility. Only 1 page at a time.
Any advice is appreciated as setting check or maybe reload scan utility ?
01-28-2020 04:08 PM
Hello.
Try using our IJ Scan Utility program to perform the scan. The "Document" option of the product is used to scan PDF files. Visit the following link to download the program:
03-19-2020 06:15 AM
I am still not able to scan more than 1 page as it gets an error message. What do you suggest.
03-19-2020 06:20 PM - edited 03-19-2020 06:21 PM
Hi norristowndave.
The following article contains directions to update the printer's firmware. The printer will need to remain powered on and connected to the internet for the duration of the process:
https://support.usa.canon.com/kb/index?page=content&id=ART172523
If updating the firmware does not correct the problem, you will need to check the computer's security settings and (if installed) firewall and antivirus settings to ensure the printer is allowed to send scan data back to the computer.
03-23-2020 11:55 AM
I checked and I have the latest firware installed. I am still not able to scan more than 1 page as it gets an error message. What do you suggest.
03-23-2020 04:27 PM
Hi norristowndave,
Please follow these steps:
1. Click on the Apple in the upper left corner
2. Click on System Preferences
3. Click on Printers & Scanners
4. Click on your Canon printer on the left side
5. Click on Scan
6. Click on Open Scanner
7. Change the Format to "PDF" and place a check mark next to "Combine into single document"
Are you able to scan using Image Capture?
01-25-2020 09:22 AM
PIXMA MX492 I am geting a message " latest formware on the server " on my message screen. how do I update my printer firmware?
