02-23-2021 12:47 AM - last edited on 02-23-2021 08:09 AM by Danny
No matter what I try, I cannot get my G6020 to print from the lower paper cassette. I get error message 1000 saying there is no paper in the rear tray. It will print if I do put paper in the rear tray. The printer was working fine until it started with this problem. I've unplugged it, gone through the set-up , reset my printer, turned the printer off and on between trying the above solutions, etc. I am out of options, please help. Thank you.
02-23-2021 03:18 PM
Hi Catskillmtnwoma,
What version of Windows is installed on your computer?
If you are using a Mac, what version of OSX is installed?
02-24-2021 02:59 AM
Hi ...
I'm using macOS High Sierra on my mac .
Thank you .
03-24-2021 03:59 PM
Hi Catskillmtnwoma,
Please click the magnifying glass in the upper right hand corner on your computer. In the Search box, please type TEXTEDIT and then open that application.
In the window that appears, please type a few words and then click on File and then Print.
In the Print Options window, at the bottom, if you see "Show Details", please click that button. If you see "Hide Details", please continue.
In the middle of the print menu, click the TextEdit drop down box and select Media & Quality.
From the Feed From drop down, please select "Main tray" and then please attempt to print.
