01-15-2016 03:35 PM
The printer is coneccted using a usb cable and i am running windows seven 64 bit
01-21-2016 02:08 AM
Hi hotfuz1,
We can try reinstalling the drivers to get the printer printing again. Please click here to go to the Drivers and Downloads page for the PIXMA MG5422. Once on the page, please do the following:
1. Verify that the operating system detected in the "OPERATING SYSTEM" field is correct, and if it is not, please click the drop-down menu to select your operating system. Please note that you may need to scroll up or down in the list to select your operating system.
2. Next, below the red box labeled "RECOMMENDED DOWNLOADS", locate the MP DRIVERS file, then click the SELECT button to the right of the filename. When you do, a dark gray DOWNLOAD button will appear; below that, a checkbox will be shown asking you to agree to the terms of the disclaimer to continue with the download. Please click in that checkbox to agree to the terms. When you do, the dark gray DOWNLOAD button will turn red. Please click on the now red DOWNLOAD button; the file will start downloading. The time for the download process may vary depending on the speed of your Internet connection and the size of the file being downloaded.
Once you have downloaded the file, please double-click on the it and follow the prompts to reinstall the printer on your computer.
Please attempt to print again. If you still experience difficulty, please call 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays) and a Canon technical support representative will be happy to help. There is no charge for this call.
