02-04-2020 02:22 PM
I want to clean the heads, but there is no "Setup" option whenn I press the Menu key. Hoow do I access "Maintenance"?
02-05-2020 02:44 PM
Hi Oldmaven,
Please follow these steps to perform a cleaning:
1. Please press the MENU button on your PIXMA MX922
2. Use the down arrow key until the wrench and screwdriver icon is selected, then press OK
3. Select Maintenance then press OK
4. Select Cleaning and press OK
5. Select Yes and press OK
The cleaning will begin.
https://ugp01.c-ij.com/ij/webmanual/Manual/W/MX920%20series/EN/BG/Bg-Maintenance1400.html
02-05-2020 02:44 PM
Hi Oldmaven,
