Reply
New Contributor
MX922: Some text lines sharp, some text lines blurry
Hi - I have an MX922 that mostly works, but the black text printing quality is degraded.
A nozzle check shows that all nozzles seem to be working. However, the PGBK section is blurrier in the middle of the test pattern.
Color printing looks OK, and the BK printing looks fine, too.
This may be hard to describe, but the best way I can think of is this:
When printing out the Windows Printer Test Page, approximately 2 lines of black text are sharp, followed by approximately 4 lines of "blurry" text. This pattern repeats throughout the page.
Now, by "2 or 4 lines of text", it isn't exactly 2 or 4 lines, it is probably more related to position on the page, or with respect to the print head. It is just describing how I get about 1/3 of my printing sharp, and about 2/3 is blurry.
By "blurry", it can be described like this: Instead of printing a solid black vertical line like this: | , instead I see a dimmer double line something like this: || across the page for that line of text.
Is there a fix for this?
Thanks,
Alan
New Contributor
Re: MX922: Some text lines sharp, some text lines blurry
BTW, I have tried cleaning the encoder strip, and it didn't seem to have any effect.
Hello.
Additional troubleshooting will have to be done to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
New Contributor
Any fix?  Every fifth line  is OK but next 4 blurry/double verticle lines.
Highlighted
New Contributor
I have the exact same problem.   The black text has a double image 1/16" apart horizontally, but every 5th line or so is clear.
Did you ever get a fix?
New Contributor
[ Edited ]
I have the same issue...on the same toner cartridge. Also did factory reset and all cleaning methods
New Contributor
What link?
Super Contributor
[ Edited ]
Hello Milvet!
Welcome to the Canon Forums and thanks for your inquiry!
To reach our US-based technical support team, please click the word "Contact Us" in Michael's post or go to  http://Canon.us/ContactCF.
We hope this helps!
New Contributor
Seems like this is a design problem that should be covered automatically with some sort of extended warranty.   I can't use my printer to print anything professional because of this glitch.
[ Edited ]
Hello.
If this printing issue persists, please contact our support group by calling 1-800-OK-CANON (1-800-652-2666).
powered by Lithium
