03-21-2020 09:36 AM
Magenta showed empty so replaced it (with Canon OEM). Then I got error code (1681) alleging more than 1 of the highlighted ink color installed (not true as I verified I had one of each installed). I turned off the machine, restarted and then got a new error code (1413) "the following ink tank cannot be recognized" referring to the large black cartridge. I installed a new one (again an OEM Canon), then restarted again. Now it's code 1410, alleging my (OEM) Magenta cartridge cannot be recognized. Obviously this "musical chairs" situation with cartridge error codes is not due to the cartridges themselves. Is there a way to reset the entire machine to factory settings and hopefully clear out this inconsistency?
03-23-2020 01:36 PM
Hi motownrocker,
It is recommended that you contact one of Canon's Technical Support Representatives via phone. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
03-24-2020 08:36 AM
I did that. They offered to send me a "replacement" but a far inferior model, as this defective 922 series is no longer produced (for good reason, I am sure, based on the number of issues owners have had).
This will be my last Canon purchase..........
04-26-2020 07:26 PM
I have the same problem
04-26-2020 07:47 PM
Does the rest of your cartridges light up after inserted? Usually a bad cartridge's light will blink red instead of being constant.
I ended up buying a new (yellow) OEM cartridge and everything works fine now. Weird, because the faulty other yellow cartridge was full (and an original Canon). Maybe a contact was broken on it or something.
