07-24-2015 01:40 PM
My MP560 stopped printing black text. Ink cartridges are full. Test pattern prints all colors perfectly. But when I print a doc from my PC or laptop only the colored text prints.
I've used the Utilities meno to do a clean and deep cleaning. No help.
I've checked the print cartridges for stray bits of plastic that might keep ink from flowing. No help.
I followed bgnewjersey's suggestion, watched this YouTube video on removing and cleaning the printhead (https://www.youtube.com/watch?v=ZheZf-vdho8) and did the cleaning. Reinstalled and the printer still prints all colors including black on the test pattern but won't print black text when I print a document.
Any other ideas?
07-26-2015 11:20 AM
I have an MX860, it also stopped printing anything Black, Tried everything know to man to fix this problem, It is my judgement that the problem is in the circuit boards in the printer it self. Reloading, rebooting, reinstalling did nothing. Here is my fix for the problem. If it is an issue with the printer it self telling the print head how to print, I figured lets try having the printer give the print head a different set of instructions. I pulled up a black and white document in Word, went into printer setup, Changed the MEDIA TYPE from PLAIN PAPER to GLOSSY PHOTO PAPER. You can leave it on standard print quality. On the MX860 it will load paper from the REAR try in this mode. I also checked the box in the lower left to use these setting for all future prints. When I click PRINT, it loaded paper from the rear tray and printed the document perfectly. I also printed out a 4 x 6 photo and it also printed prefectly. Yes it did take longer to print the document but " so what " in my case to wait a little longer is not a live changing issue. The bottom line is that with the printer set in the Glossy Paper mode it prints anything black or color perfectly. Obviously this fix does not address the origina problem which in my opinion can not be fixed.
07-25-2015 11:10 AM
As to 5600 print problem.
I m made mistake in when useing and testing in dialog. It never showed in nethier dialog or, using..
I ended up with person from h. p. that wanted all facts and asking of warranty when purchased. I It was was as 30 day return offer if retuning and a warranty was $15 fot 3 years, which I never bought , thinking my previous h p printer went almost 12 years with no trouble so, that the main reason never bought warranty . .. Aso, I went to 4 hour test where they take control of printer. No answer there. Cost $200.
So ;it sits in closet after just a few months being used.
Bought another but it a Canon.
Thanks for all help from the forum people.
taper21
07-26-2015 11:20 AM
07-26-2015 11:47 AM
Well well well .. who would have guessed, but docs now print perfectly.
Thanks so much for this. Glad I won't be having to replace my printer just yet. When I do I'm not sure it'll be another Canon.
02-02-2017 12:04 AM
Wow! This is the only solution of the many offered that worked for my "Canon MX868. I am very pleased that you posted this information on the forum. The dodgy responses from Canon were especially useless. You've saved me the cost of a new printer.
02-22-2017 06:58 PM
Wow your solution really worked!!!!! I've been trying to solve this issue for hours and your idea solved it!!!! Thaaaaaaaanksssssssssssss
01-25-2018 02:14 AM
Thanks so much! It's now 2018 and this info has been a godsend!
05-26-2018 09:05 PM
this fixed my issue
11-06-2018 08:17 PM
Thanks Ramona, the bypass worked. However I'm surprised Canon have not solved and fixed the original problem - why the larger black ink tank won't work.
07-10-2019 07:20 AM
Oh my goodness - thanks for this solution! I have literally been pulling my hair out trying to figure out why my canon mg7550 wouldn't print black text in either work or all of a pdf doc. I've selected the glossy print instead and bingo it works having gone mad trying everything else! Word docs now print black text but it's annoying that it'll only take ink from the small cartridge not the big one which I just replaced trying to solve the problem! Weirdly though if I printed a jpeg document it printed black text perfectly but pdf I have to take a snapshot, save as a word document and it prints ok on normal settings. It's sooooooo confusing but thank you.
