11-09-2017 12:16 AM
After installing macOS 10.13.1 (High Sierra) MP Navigator EX 4.0 has ceased to work.
11-13-2017 02:31 PM
Thanks, Mark. In the elegance stakes, that solution scores zero, I'm afraid! Fortunately, by updating MP Navigator to v4.0.5 and reinstalling the IJ Network Tool in its latest version, all problems with my MG 6150 have been overcome. Took me a couple of hours to sort that out and I would have hoped for an auto-update from Canon, to be honest, but the job's done, thankfully. Hopefully this might help other sufferers.
01-06-2018 12:20 PM
I have a pixma MG5320 printer and I have tried all the different scanning software options stated previously for MP Navigator. None of them have worked. All I get is folder with a read me text, I do not get any upgrades, even going down to Maverick. I am able to scan directly from the printer using a USB memory stick which is cumbersome but is the only work around I have figured out. Does anyone have any idea about my model printer. Thank you.
01-09-2018 10:36 AM
I also tried some of the suggestions in this thread. I have a Pixma MG5350 and suffered the same issues, until I got a fix that worked for me.
I have two iMacs, both running High Sierra 10.13.2, but got different symptoms on each machine, when trying to open MP Navigator. When searching for MP Navigator 3.1.5, I installed this TWAIN driver (more in desperation than hope):
http://support-th.canon-asia.com/contents/TH/EN/0100432802.html
This didn't work with MP 3.1.5, so I re-installed MP 5.0.4, and MP Navigator finally opened up, but I still had trouble finding the device.
I tried deleting and re-installing the printer/scanner in System Preferences (don't select the default, search for a new printer) - on my old iMac the printer options were "Bonjour Multifunction" or "Canon IJ Net" - I selected the latter which worked. (I've had issues with Bonjour before). On my other, newer iMac "Bonjour Multifunction" worked.
A lot of trial and error, but hopefully this may be able to help someone else!
01-06-2018 01:10 PM
01-11-2018 12:44 PM
I installed High Sierra and the scanning function of MP Navigator no longer works on my Canon MX420 printer. Are there any driver downloads or patches that I can access to fix this?
Thanks.
01-11-2018 02:50 PM
There are 12 pages of discussion, many giving work arounds for your problem. I got my MC 870 to work by installing MP NAv 3.1.5. Read the many pages before your post for directions on how to find this and load it.
Canon still hasn't fixed the problem and seems to not care. Don't buy Canon until they get the message that support counts.
01-11-2018 06:26 PM
I read all the 12 pages and tried some of the work arounds but they did not work for my .MX420. Thanks for trying, Canon certainly hasn’t,
01-13-2018 09:22 AM
Disappointing Canon. Ill remember this the next time I need to purchase an electronic device.
MP560 with mac high sierra.
01-14-2018 10:06 AM
I managed to get my MP990 fully functional with High Sierra.
The trick was to install the MP Navigatro 3.1.5 version mentioned earlier and rename it in the program folder from "3.1" to "3.0".
After that initiating the scan from the printer worked again as before.
IMHO Canon uses a simple mapping from the printer model (i.e. MP990 in my case) to the MP Navigator Release number (here 3.0). So maybe this works for other printer models as well.
01-14-2018 01:19 PM
MG8150 doesn't function with High Sierra
01-14-2018 08:02 PM
Since the las update of my Macbool Pro to High Sierra 10.13.2 I have not been able to scan. Any suggestions to fix the problem. Need it URGENT.
