02-14-2018 02:34 PM - edited 02-14-2018 04:40 PM
The printer was working well, no problems. Nothing changed and then this issue popped up. ANy print job I send will go to the queue for a moment and disappear for good. The screen on the printer will give me ththe Processing... Please wait momentarily, as usual, and then go back to the main screen. The inkjets don't fire up. Nothing.
I have powered down and back up, both the PC and printer several times, to no avail. I've unplugged the usb and reconnected. I even (finally) set up the wifi connection and tried that. Same result. Then updated the drivers and that had no effect. I was able to use a separate b/w printer but this I cannot figure out. Can anyone please advise?
Finally solved this. Went into Windows/Spooling settings.
