12-13-2017 12:07 AM - edited 12-13-2017 12:08 AM
Im unable to print a DVD/CD from My Image Garden. It never gives me the option to pring from the disc tray feed. (using a MG7720)
12-12-2018 03:27 PM
A critical point was not mentioned by the Canon representative. After you install the drivers as they recommended, you have to go back to the My Image Garden preferences under "General" and uncheck the box that says "Print/Scan using Airprint". Once I did that everything worked as per the instructions
12-13-2017 08:18 AM
Hi there!
So that the Community can help you better, we will need to know which Computer Operating System you're using (Windows Vista/7/8/10 or macOS 10.x), as well as the way you connect to your device (USB or networked via WiFi or Ethernet).
If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team by phone or email.
Thanks and have a great day!
12-13-2017 10:34 AM
Im using a Imac operating system (OS El Capitan Ver 10.11.6) im also using my WIFI to connect to the printer. It never gives me the option to print from the disc tray feed, it only want to print from tray 1 or 2....
12-13-2017 10:41 AM
Hi there!
You'll want to make sure you're using the Canon drivers and not AirPrint. AirPrint won't typically allow you to change paper type/tray.
You can get the Canon software and drivers from our site HERE.
If you've installed the Canon drivers and software, and you're still having difficulties, we'd recommend reaching out to our friendly, US-based support team at 1-800-OK-CANON (800-652-2666) weekdays from 10am to 10pm (ET). Support at Canon USA is always free.
If you're outside of the US, click HERE for support options in your country or region.
12-12-2018 03:27 PM
02-05-2019 06:44 AM
02-05-2019 10:31 AM - edited 02-05-2019 10:32 AM
Finally sussed out how it's done, I can now print a DVD on my Pixma ip 7250, thanks for that valuable piece of information.
08-06-2023 08:00 AM
You are my hero. You brought my frustration to an end. How am I supposed to know this? Its not even in the printers manual. Thank you so much!
09-24-2023 11:52 AM
Just done that. Then the software does not let me choose L (CD) anymore.
