Reply
New Contributor
I need help with a print spooler error message
Out of the blue I lost my printer connection.  When I look at my printer menu there is no printer listed.  When I try to add or install a printer, I get some odd message about a printer spooler is not running.  Restart the machine.  I've tried unhooking the printer, rebooting, unhooking from the power source.  I even went into some area as an administrator and found the print spool task and when I clicked on the start button there was no action.
Occasional Contributor
Re: I need help with a print spooler error message
This is a MS Windows issue. Try this:
Right click on My Computer
Select Manage
Double click on Services and Application
Scroll down to Print Spooler and double click on it
Click on Dependencies tab
Check what dependencies the print spooler has, if any you may need to click on + on those dependencies to more dependencies
Go back to the Services list
On each of the spooler dependencies, double click on it
Make sure it is set to Automatic in the Startup Type drop down menu
Now click on Start to start the service
Click OK
Now try and print.
Reputable Contributor
Hello Kendra!  In order for the community to better assist you, we’ll need to know the model of the printer you are using.  This will ensure the most accurate information is provided.  Thank you and have a great day!
New Contributor
Hello Jason,
I actually just ran into this problem myself and while looking for an answer, I ran into this post. I have a Pixma Canon MP250 and I also have Windows 8.1. Is there a way to fix the spooler problem so that I can use my printer once more? It's so weird because I was using it just yesterday and today out of the blue it stopped working and I have no idea whatsover what 'caused it. Any help would be greatly appreciated! Thanks in advance.
-- Maria
Hello.
The Print Spooler service is a Microsoft service.  This has to be running properly in order for printers to work.
If the service is being stopped, please contact your computer manufacturer to investigate what is stopping the service.
New Contributor
How I corrected Printer Spooler Error Message
Printer Spooler Error Message:  I found that by going into the Windows Control Panel, then selecting:  "Program and Features" you will see the heading on this page: : "Inistall or Change a Program" ... to the left of these words on this same page,, you will see a small Windows Shield and the wording:  "Turn Windows Features On and Off."    I then selected that option and then, within that option, went down the alphabetic list to:  "Printer and Document Services"   -- In my situation, the Printer and Document Services box along with the related services boxes below were not checked.. just a dot mark.. My printer and computer had been working just fine.. how this got changed is not understood.....
I made certain all boxes under Printer and Document Services were checked and then my printer started to work and the "Printer and Spooler Error Message" went away.... In my stiutaiton this appeared to be a Windows problem not related to my Cannon MP280 printer which works just great for me...!
New Contributor
Re: How I corrected Printer Spooler Error Message
Thank You!! Your steps worked perfectly so strange that this happened...
powered by Lithium
