11-19-2015 10:37 PM
Mx922 error support code 1007, there is no paper in cassette upper. I have paper in the bottom cassette. The upper cassette is for envelopes pictures etc... I checked the paper and adjusted to fit tight and it still won't print.
03-25-2020 11:15 AM
03-25-2020 11:15 AM
03-25-2020 11:17 AM
03-25-2020 12:43 PM
03-25-2020 03:35 PM
Check your settings in the print dialog box. Be sure you are trying to print 8.5x11 size paper from the lower cassette and not the photo (upper) cassette.
05-08-2020 05:13 PM
05-09-2020 02:07 PM
I have the same error, but I have already set the paper size and checked to make sure it is going to the default lower tray, and i still get this error. There has to be someway to change this function, it is making the printer useless. I have tried printing an e-mail and a pdf, and a spread sheet all with the same useless behavior. I would like to disable the upper tray completely, and only enable it by choice which is once in the past 5+years.
05-09-2020 02:44 PM
