11-09-2013 01:31 PM
I am embarrassed because I never thought I would have a problem getting paper to fit inside of a tray. I can figure out how to put the 4 x 6 and the 5 x 7 but I can in no way figure out how to make the 8 x 10 work. It will not open up wide enough or long enough.
Help!!!
Thank you so much
ancient
11-16-2013 10:00 AM
Hello ancient11.
To try and resolve the 5011 error, please turn the printer off and back on again.
If the error still remains, please contact our support group by using the following link below.
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
11-09-2013 01:50 PM
I finally found the second tray--my bad-blush! Now to figure out CD-- no instructions with this printer--thier bad!
thank you
11-11-2013 05:48 PM
Well now I have error code 5011, I am lost. I guess I will return it unless someone here has pity on me and tells me how to fix it. Being 82 yrs old does not make you very electronic savy.
11-16-2013 10:00 AM
Hello ancient11.
