Reply
New Contributor
How to clear paper jam in MX922?
[ Edited ]
101 paper that came with the printer into the wrong tray. I fed it into the regular tray. Now I got the error message that said there's a paper jam inside. I've opened all the doors and trays that I could find but I didn't see the papers. I can't see the manual online for some reasons and Canon's help line is closed at this time. I couldn't finished setting up the CD driver because of the error message on the printer. I'm truely stuck.
Does anyone know how to clear up paper jam in MX922? Thanks.
Re: How to clear paper jam in MX922?
Hi jckny,
Please click on the word "Troubleshooting" located at the link below to view video instruction on removing paper jams and obstructions from the printer.
PIXMA MX922 Instructional Video - Removing Paper Jams and Obstructions
I hope this helps!
Occasional Contributor
The videos for troubleshooting are in its own tab, which the URL above itself doesn't take us to; I had to manually click the tab.
[ Edited ]
If anyone else has nonfunctional printer due to a paper jam error code, and you've tried everything else, and the code won't go away-- here's something else to try:
Turn off the printer, remove the trays, manually feed the edge of a sheet of cardstock into the paper pickup rollers (gently),  replace the trays, and turn the printer on.
The startup procedure will pick up the cardstock and run it all the way through the system, hopefully clearing out the pathway.    Worked for me--  http://community.usa.canon.com/t5/Printer-Multifunction-Support/I-fixed-my-persistent-1311-error-pap...
New Contributor
You are a genius!  I didn't have card stock so I cut the tab of a file folder and followed your directions.  When I turned the printer back on, out came the folder with a little piece of paper.  Mind you, I have been trying to clear this thing for 3 hours!
Thanks!!!
Highlighted
New Contributor
https://www.usa.canon.com/internet/portal/us/home/support/self-help-center/how-to-video-library/how-...
Try this link.  It took many tries, but I actually found the video (Video Libraries).  The link  in the first e-mail response did not work, only showed a sales video.
New Contributor
Holy moly...this worked like a charm! You are a genius! I never would have thought of that. Thank you SO MUCH for sharing this fabulous tip...I'll remember it for the future!
New Contributor
Do you put the cardstock in the front or rear?
powered by Lithium
