11-30-2019 11:12 PM
I've had a G2000 for a good while now, but have been using it only for b&w documents - been awhile since I printed a color pic - but what is supposed to be red is coming out a sickly yellow-green and my grey is a weird blue-green. My ink bins are all at least halfway full. Troubleshoot says I don't need a driver update. Any ideas? Thanks. (The "ACK" in the pic is supposed to be red, and the color of the bit of werewolf you can see should be slate grey)
11-30-2019 11:31 PM - edited 12-01-2019 08:19 AM
Normally some color ink is used even when printing B&W, but environmental factors, heat, humidity, etc can also affect delivery. If you have only been printing B&W documents, its possible some of your inks or nozzels might have dried up or become partially clogged.
Try performing a print head cleaning, then a nozzle check pattern and see if this helps.
~CarePaks Are Worth It
12-01-2019 02:58 PM
After 2 regular nozzle cleanings, with no magenta coming through at all, I executed a deep cleaning and that did the trick! Thank you very much.
11-30-2019 11:25 PM
My computer is using Windows 10.
12-01-2019 02:58 PM
12-01-2019 11:31 AM
You mention printing mostly black and white documents. Is it possible that you have made some changes in the printer's driver settings to optimize for text or B&W printing?
12-01-2019 02:59 PM
Thanks for the suggestion, but, no, it appears my magenta nozzle had clogged up. I appreciate the input!
