09-25-2014 01:04 PM - last edited on 05-19-2023 09:40 AM by Danny
I have a Cannon MX922, i am getting code "5011" cancel printing. Turn off and plug in, if problem persist call support. I did so and i am asking for help. did not work.
11-02-2017 11:31 AM
AnnP,
Troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
09-29-2017 07:24 PM
Brilliant, tried everything and was about to use it as a missile until I read your solution. To my surprise it works perfectly again, a thousand thanks. How on earth did you come up with that solution?
09-30-2017 11:59 AM
Hey I did this and now the printer will not turn at all. Nothing.
11-02-2017 11:31 AM
AnnP,
11-02-2017 11:43 AM
Thank you so much. Sorry, I don't see the accept as solution button. The printer DID come back fine tho after it was off for a couple days. Maybe I didn't follow the instructions correctly the first time. Thank you for your help. I do appreciate you.
11-02-2017 02:16 PM
10-20-2019 11:47 AM
Apparently, when you tell Canon here what you really think of their product, they delete your post.
Let's see how long this one lasts under our freedom of expression rights
04-28-2020 08:48 PM
Garbage printer. Replace the black ink for the first time and get 5011 error. Have done everything in this thread. Nothing. DO NOT EVER BUY A CANON PRINTER.
02-14-2020 07:39 PM
Buenas tardes, tengo una canon pixma TS9120 con codigo 5011, ya revise y no encuentro nada que obstruya el paaso de la hoja. ¿que puedo Hacer?
05-18-2023 05:26 PM
I had this error code as well, to fix this issue power off and unplug it before it gets shut down all the way. I tried to power off and unplug it but didn't work so I decided to try power off and unplug before it shuts off, it worked on mine. Hope this helps everyone who has error code 5011
