08-13-2019 02:22 PM - last edited on 07-15-2022 08:25 AM by Danny
Hello,
When I print a document to the Pixma MG5320, one of the Printer Features is called DuplexSurface.
The choices for this setting are zero and 1, with a default of zero.
What is it? What does it do? And when would I set it to 1?
Zero is the amount of online info about this setting.
Thank you in advance.
08-21-2019 09:29 AM
Hi billds,
Canon has not released a driver for the PIXMA MG5320, as it is not supported with macOS v10.14.
It is unclear as to what that option does, as it is not part of a Canon driver.
08-15-2019 02:11 PM
Hi billds,
So we can best assist you, please reply with the information to the following questions.
Also, could you also take a picture of the settings and attach it to your reply.
We look forward to hearing back from you.
08-15-2019 03:19 PM
Hi ArthurJ,
08-21-2019 09:29 AM
Hi billds,
07-14-2022 04:16 PM - edited 07-14-2022 04:17 PM
This is a very odd reply. In the driver for MacOS 12.4, that I just downloaded for a recently-purchased iB4120, I get the identical “printer features” list of options that @bilds shows. And from my wife's iMac where I just downloaded a driver for 12.4, we see the same list of options for our home MX922.
This “feature” is definitely a part of Canon software.
I went looking for this because Microsoft Word recently mangled ITS print dialog interface, to remove the Duplex option; I was able to solve it by using Safari's dialog to set a default mode that prints Duplex. However, Canon software exposes this option that IMO ought to be removed or documented; the odd feature delayed my finding the answer I sought.
