04-30-2018 09:51 AM
My MG7520 has died.
What current printers utilize the above ink cartridges. I hate to waste the 20 I have on hand.
Thanks
05-01-2018 07:23 AM
Hi frjeff,
The following printers use the PGI-250 and CLI-251 ink tanks:
PIXMA MG5220
PIXMA MG5420
PIXMA MG5520
PIXMA MG5620
PIXMA MG6320
PIXMA MG6420
PIXMA MG6620
PIXMA MG7120
PIXMA MG7520
PIXMA MX922
PIXMA iP7220
PIXMA iP8720
PIXMA iX6820
04-15-2019 02:15 AM
Good answer, but .... if I want to do the same and buy another Canon printer, I'd prefer to get the latest model of the above listed printers. However I can't find a list online anywhere that puts a chronological listing of when the printers were made. Can you help me find the NEWEST of the above?
Thanks in advance for your help!
LS
12-02-2019 10:34 AM
Hi
Did you ever get an answer? I suspect you are in the same position - your printer died but you have WAY too much ink and you'd like to replace with a newer model that uses same ink? Did you find a solution? Thanks
07-20-2019 06:57 PM
are these the current list of canon printers compatible with CLI-251XL and PGI-250XL Cartridges?
12-06-2019 12:49 PM
02-14-2020 04:21 PM
Yeah, I'm in the same situation. I was told the TR8520 could use XL 251 ink. However, it calls for 281. The cartridges fit, but the printer doesn't recognize them. If there is a way to still get it to print, even though it can't detect the ink levels, I'd like to know. It doesn't seem to work for me.
02-24-2020 09:44 PM
Did you ever get a solution to this?
I have the same issue
Printer is a 7520
Previously had 281 cartridges
Tried to install brand new 251 cartridges
Keep getting the 1660 error message.
Have tried several times to remove and install again
HELP!!!!
02-26-2020 03:38 PM
Hi tkwasny,
The PIXMA MG7520 is only comptible with the following ink tanks:
CLI-251BK
CLI-251GY
CLI-251Y
PGI-250PGBK
CLI-251C
CLI-251M
The CLI-281 ink tanks are not compatible.
02-14-2020 04:51 PM
