04-20-2020 01:55 PM
05-05-2020 03:05 PM
Hi SGlinick,
The MX922 can work with WPA-2 so it should be compatible. If you have a new router, the printer would need to be connected to your new network to continue working. You can connect the printer to your network using the steps in the link HERE. Since you are using an EERO router, you can select the option for multiple access points if it comes up.
