04-29-2015 06:04 AM - edited 04-29-2015 06:27 AM
Hi I have an Canon ipf 4600 Large format printer, it doesn't get a lot of use, it is just 13 months old, I try to use it once a month and run off a few 24 x 36 inch posters
Today I run it up as per normal, it always completes a cleaning cycle before use and a Nozzle check which completed as per normal.
However the first print I did I noticed small random black ink spots on the print, they were still wet and about the size of a small pin head about 1 -2 mm diameter these continued all down the print about 10 on a sheet of 24 x 36 poster.
On the second print I didn't see any further ones? 🙂
Previously I had installed a new 130ml Black (BK) cartridge, could changing this for a full one caused this to happen?
Thanks
