09-03-2019 02:05 PM
I have both a Canon MX870 and a Canon MG5620. I am using these printer via a wireless connection through a router to two current version Apple iMac computers. They both work fine currently within Mac OS Mojave 14.6. Any idea whether these two printer will continue to fully operate under upcoming soon to be released Mac OS Catalina? Your assistance will be appreciated.
Best regards, Larry
09-03-2019 10:10 PM
@larryis1 wrote:I have both a Canon MX870 and a Canon MG5620. I am using these printer via a wireless connection through a router to two current version Apple iMac computers. They both work fine currently within Mac OS Mojave 14.6. Any idea whether these two printer will continue to fully operate under upcoming soon to be released Mac OS Catalina? Your assistance will be appreciated.
Best regards, Larry
Best to contact Canon. They may or may not have an answer.
We can only speculate.
No drivers for MX870 in Mojave
Drivers for MG5620 released 9/2/2018 for Mojave.
My guess. MX870, yes
MG5620, maybe
Hope it works out for you.
10-18-2019 10:56 AM
Looks like the MG series has printer/scanner drivers for 10.15 in the support area. HOWEVER, neither the IJ Scan Utility, nor the Image Garden (which is relatively worthless IMO) , nor any other of the ancillary pieces of software have 64-bit drivers. Therefore, you will not be able to initiate a scan from the panel, as I am led to believe.
11-03-2019 04:12 PM
I have upgraded to Catalina and can verify the IJ Scan Utility will not run in this environment. This leaves me with 2 questions.
1. Is there a version of Scan Utility for Catalina?
2. If I buy a new Canon printer will I be able to scan documents running Catalina? How?
Thank you.
Hector Caroselli
11-03-2019 06:10 PM
Hector,
So were you able to print on the Canon MX870, as that was what my inquiry primarily focused upon?
@hcaroselli wrote:I have upgraded to Catalina and can verify the IJ Scan Utility will not run in this environment. This leaves me with 2 questions.
Thank you.
Hector Caroselli
11-04-2019 04:40 AM
Printing SHOULD be fine. However, the question about "fully" function has opened this up to scanning from the printer as well. I believe the printing/scanning initiated from an Apple product upgraded to Catalina, but from the panel; I doubt it seriously. For this and other reasons, I will not be upgrading anytime soon.
11-04-2019 11:32 AM
Unfortunately my only printer is a Pixma MG5520. Printing seems OK but I cannot use the Canon IJ Scan Utility.
11-04-2019 11:46 AM
Why can't you send scan job commands from Image Capture within Mac OS? I have used image capture in OS Mojave and it works just fine. Any reason to be Image Capture will be problematic within OS Catalina?
Larry
11-04-2019 12:00 PM
What we are trying to say is that we cannot INITIATE a scan from the panel, which requires the Utility. This 32 bit needs to go to 64 bits, which is supposed to happen this month. Certainly, the native Image Capture app will function.
11-04-2019 12:12 PM
I just looked at Image Capture very briefly. I don't see a way to scan; unless I first have to photgraph a document with my iPhone. I am not sure I know what you mean. FWIW the Canon IJ Scan Utility was very convenient. Put the document on the scanning bed of the printer, launch the utility and follow the instructions.
I am not opposed to buying a new printer, mine is pretty old, but if I buy a new printer I want to make sure I can scan with it.
