Canon Pixmar MG2520
jwjw427
Can this printer be set up to print labels? Im trying to figuer out how to set it up to print a 2" X  4" Label sheet. Any help will be great.
2 REPLIES 2
jwjw427
Is there any Canon People monitoring this page or is it Poke and Hope !!
James_C
Moderator
Moderator
Hi jwjw427,
There is no specific setting within the driver of the Canon MG2520 that will allow you to set it up for printing labels.  However, the printer should allow you to print labels if they are on a 8.5 letter size sheet of paper.  You will also need a program that allows you to format the labels.
You can use the following page sizes.
Standard sizes:
 Letter
 Legal
 A5
 A4
 B5
 4" x 6" (10 x 15 cm)
 5" x 7" (13 x 18 cm)
 Envelope DL
 Envelope Com 10
Non-standard sizes:
You can print on non-standard size paper within the following ranges.
Minimum size: 4.00 x 6.00 inches (101.6 x 152.4 mm)
Maximum size: 8.50 x 26.61 inches (215.9 x 676.0 mm)
Paper Weight
You can use paper in the following weight range.
17 to 28 lb (64 to 105 g/m2) (except for Canon genuine paper)
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
