07-29-2014 11:21 PM
I have a Canon PIXMA MX882 printer which worked great for the past three years then 2 days ago,will not turn-on
I've unplugged it and let it go for a time then plugged it back in and nothing..... any ideas?
08-01-2014 05:25 AM
Hi DavidDellinger,
It is recommended that you contact live technical support . There is NO charge for this call. Real time feedback of a live technical support call would be very beneficial in this case.
Please dial 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays). A Canon technical support representative will be able to resolve this issue faster.
01-02-2015 11:43 PM
Hey DavidDellinger;
I have had a similar problem. If you are getting a B200 error - kiss your printer goodbye,
something has cooked.
If it just doesn't turn on at all, check your power line - is the wall outlet working, are your plugs
tight. Try wiggling things.
That is probably the same advice you got from Customer Service. One thing different though,
I'm not going to sell you another Canon printer.
If you got three years out of it, thank your lucky stars and move on.
For more info, see the thread below.
Re: Pixma MX 892 Won't Turn On
Good luck.
-B
