Canon MG5650 Paper has run out error
karawr
I recently bought a Canon Pixma MG5650 and I have to say I have never been so disappointed in a printer before. One would think that with all the positive reviews, there would be something good about, but I have only encountered problems sine receiving this hunk of trash.
I have printed many different sized documents, so I am familiar with changing the cassette and its settings in order to accommodate.
I am trying to print a 4x6 glossy photo, which I have registered with the cassette settings, however every time I try to print it says "Support Code 1003: There is no paper."
2 REPLIES 2
himacc
canon error 1003 solution
Press the HOME button, select SetupDevice settings, and Print settings in this order, and then set Prevent paper double-feed to ON.
other
Press the HOME button, select SetupDevice settings, and then select cassette incorrect paper detection to No
this will solver error 1003
mutleyhb
I ran the following and it worked-
Go to Set Up, select Maintenance and then Roller Clean : )
