05-25-2017 07:07 PM - edited 05-25-2017 07:08 PM
Hello to all Canon friends,
I have an issue with my Canon MG 2520. I black strip/line is appearing when I scan a document.
I have attached an image so you can see better.
I have searched many post similar to this issue but none have worked to find the solution.
(Cleaning/Hard Reset)
Thank you beforehand for your help and time in helping me resolve this issue.
05-26-2017 01:46 AM
Hello,
Do you experience the same issue when making a photocopy directly from the unit as well as when trying to scan?
Should you need more immediate assistance, please contact a Canon technical support representative at one of the methods provided here. A representative will be happy to assist you free of charge.
06-06-2017 02:03 AM
Yes, the line appears on both whenphotocopy and scan.
What can I do to fix it?
06-06-2017 09:39 AM
Hi MyMG2520,
It is recommended that you contact one of Canon's Technical Support Representatives. To contact a Technical Support Representative, please use the link below:
http://Canon.us/ContactLI
03-06-2019 11:50 AM
Hello I have the same issue , When printing everything is fine but when scanning or photocoping I get a thick solid black line approx 1/2 inch down the side of the doc . I have cleaned , I have factory reset , I have updated firmware , but still the same . you can see the black line on the scan preview and it doesn't matter if you move the paper to a different spot on the scanning bed or it you completly cover the scan bed with multipul sheets of paper . the settings are set to A4 for an A4 sheet , I can send you a photo of the printer preview lcd screen with line on it , if you need it . ty
