02-06-2019 12:24 AM
I have my cannon g2000 printer. however, if the printer is idle for approx 2 minutes and I try to give the print, it hows "port in use, please wait". After a few seconds the printing starts. It is delaying my print jobs. Please help.
I Have tired to reinstall the printer still the same issue. Also tried to remove the driver completely and installed it again, still the same issue.
Please let me know if someone else have the same issue or is there is any resolution for this.
02-12-2019 01:23 PM
Hi vghemud,
So we can best assist you, please let us know if your Computer is a Windows or Mac.
02-17-2019 05:20 AM
The printer name in the control panel is Canon G2000 series printer and the port name shows USB001 Virtual printer port for USB cannon g2000series printer. Please check the screenshot for the same.
02-19-2019 03:20 PM
Hello.
Uninstalling and reinstalling the drivers may help with this issue. Please disconnect the USB cable from the printer. Then restart your PC and perform the following:
2. Open "Programs and Features", or "Uninstall a program".
3. Uninstall the G2000 series MP Drivers.
4. Go back to the Control Panel.
5. Open Devices and Printers.
6. Right-click and delete or remove any copies of the printer that are listed here.
Once this has been done, visit our website at the following link to download and reinstall the G2000 series MP Drivers.
PIXMA G2200 Drivers & Downloads
02-12-2019 09:17 PM
02-15-2019 12:33 PM
Hi vghemud,
Please open the control panel on your computer and then select "View Devices and Printers". Once you are there, please let us know if there is a WS at the end of G2000 printer icon( G2000 seires WS). If you could also right click on the printer icon and select Printer Properties.
In that new window, select the Ports tab and let us know what port has a checkmark.
05-02-2019 01:11 AM
05-03-2019 04:19 AM
Hi MunafXI,
I understand that you are trying to print to your wireless PIXMA G2000 series Printer and you are being told that the port is in use from your Windows 7 and Windows 10 computers. I can help you with this issue.
Computers communicate with other devices through ports. You can think of them as doors that only one person can fit through. If the port is in use or being blocked, your computer will not be able to communicate with the printer. The fact that the printing eventually does start tells me that this is an intermittent issue. Whoever is blocking the door sometimes steps away.
Security software can sometimes interfere with the communication process. Therefore, if you have any of these programs (Firewall or Anti-Virus Protection), I recommend that you disable them before printing. If that does not help, sometimes restarting the computer will fix this particular error.
If you are still having an issue, I recommend that you delete the printer and uninstall the original driver. You can delete the printer from the "Devices and Printers" window. Then, you can uninstall and reinstall the MP Drivers.
Please do the following on your Windows 7 computer:
When you have finished installing the Printer Driver and creating a wireless connection, you should try printing.
Please do the following on your Windows 10 computer:
Please write back if you are unable to do either one. In your reply, please include the full error message you are getting when you try to install the software or use the printer.
