Reply
Highlighted
Occasional Contributor
Re: Call to Arms for the dreaded U052 Wrong Printhead Error
Just got the dreaded 1403 error message on my pixma MX922 printer!!!
“The type of print head is incorrect. Install the correct print head”.
First time I’ve ever had this message. Any resolves?
Highlighted
Hi GuzCanon,
You can try performing a reset of the printer. While the printer is on, unplug the power cord from the printer and let it sit for 60 seconds. While the power is off, press the power button 5 times. After 60 seconds plug the power cord back in and power on the printer.
If that does not resolve the issue, the print head has failed. You can order parts through our Parts department. Please note that items purchased directly from our parts department are not returnable and there is a chance that it will not correct the issue you are currently experiencing.
For the price and availability of parts, please contact the Parts department below by calling them directly at 1-866-481-2569 between the hours of 9 AM to 7 PM (ET) Monday to Friday.
You also qualify for the Canon Upgrade Program. You can order parts through our Parts department. Please note that items purchased directly from our parts department are not returnable and there is a chance that it will not correct the issue you are currently experiencing.
Highlighted
Dear Guz,
If you read back over the many years of posts, you'll see that this is not so much a malfunction as an arbitrary limit that Canon has programmed into these printers.
You should be very cautious before parting with more money, especially if a Canon employee is advising you to do so.
Don't just take my advice on this - look back over the thousands of angry postings.
Like many others, I junked my machine, even though it had been a fine printer until the "error" message appeared - it's not an error, but a built-in machine killer of which Canon is perfectly aware.
Change the manufacturer. I went for Epsom. Quality of printing not quite as good, but Canon have lost my custom - no purchases of any kind from them for five years, approx, even though I used to rate them quite highly.
There was a class action, I believe, many years ago.
Poor corporate management, I guess. It'll bring them down eventually, to the regret of their employees.
Good luck
Paul Rapley
Highlighted
😔 Sadly, Arthur J, it did not work. Thanks for the assist but this printer is being put out to pasture. Sad to say, I will not be getting another Canon. Very disappointed in the printer that failed and the solutions suggested.
Highlighted
Hey Paul Rapley, thanks for your valued input and assist. Luck was not on my side. Unfortunately, reset didn’t work. Sad to hear that this has been going on for so long and Canon does not seem interested to solve the problem that they created. Ironically, I purchased the Canon to replace an HP after quite a lot of years with them. They used to be great and then down hill it went. I am officially giving up on the cartridges and going laser with Brother!
Thanks again Paul for reaching out. Stay well. Maggie
powered by Lithium
