04-10-2014 08:58 PM
04-11-2014 11:25 AM
04-10-2014 10:44 PM
Normally, I use the Manual mode of the camera. What I usually do is to put the camera in manual focus mode and set to infinity. You might also try setting the metering to spot meter. Make sure you are using a high enough shutter speed to avoid camera shake, and use an aperature of around f5. Too wide of an aperture (f2.0) will also blur the background, so keep the aperture to a higher number to keep everything focused. (smaller aperture).
04-11-2014 11:25 AM
04-14-2014 02:45 PM - edited 04-19-2014 03:41 PM
P mode, set to focus tracking, aim the camera so that the little square frames the sun, press the button beside the bin sign.
That will lock the focus on the Sun. Bracketing for exposures might be useful. RAW, natch. (Or RAW and JPG for easy reviewing on a pc.)
