11-26-2019 06:05 PM
Using single shot not overloading buffer camera has froze twice in 2 days. Last shot in view finder no response to any input or even power off. Had to remove battery to reset. Anyone experiencing this, fix?
11-26-2019 07:19 PM
One possible suspect would be your SD card. Use only a full-size SD card from a major manufacturer and only the type listed in your manual.
11-28-2019 12:11 AM
Hi There,
Yes, I would check to see if the problem happens with a different or with no SD card in the camera. If it still happens even with no SD card then it would be best to have the camera checked out by a repair center.
https://www.usa.canon.com/internet/portal/us/home/support/service-repair
11-28-2019 02:11 AM
11-28-2019 02:15 AM
11-28-2019 08:10 AM
Had a Canon repair center Jamesburg, NJ but has closed.
06-03-2020 10:20 AM
Had this happen with sx60 as well; had to return for warranty replacement. Happened with my first SX70, too...lens freeezes, usually extended, then have to remove battery to turn off and get it to retract. Has happend once with this, my repacement SX70 (canon warranty)...it appers to be a defect withthis whole seriesof cameras.
09-20-2020 07:56 AM
Thanks freezing more often so contact Canon site provided info and got online est to repair $279.00. It's now out of warranty so that makes it uneconomical to repair. Like the camera used to be my go to light carry around zoom but now just occasionally used with the freezing up trouble.
