Reply
Highlighted
Frequent Contributor
Re: shutter release not working S100
What is your serial number series, Markiettan?
Highlighted
New Contributor
[ Edited ]
seriel no 41803200XXXX
Highlighted
You are one of the lucky ones. Your camera is covered! Have you contacted your local Canon repair centre?
Highlighted
New Contributor
wow.. thats a pleasant surprise. any idea where is this list of covered cameras? I must admit I haven't read all 12 pages of this thread, only the first and last pages
Highlighted
New Contributor
I wouldn't get your hopes up about your camera getting covered. My camera is also within the range of numbers included in the recall, but the recall was for a completely different issue, a lens error. I'm no expert on Canon or any of this, but all my research and forum reading has shown that Canon will take the camera and diagnose the problem. If it's the lense error (which I understand is when the camera screen goes black and gives a lens error message), they will include it in the recall and cover the repair. If it's not, they will charge you for a repair.
I actually just sent my camera in for repairs for this shutter release problem, and I was charged $175, with tax and shipping, for the repair, even though my camera is in the recall number range.
Highlighted
[ Edited ]
I also have the exact same problem as many users have described.
I am shocked as usually I have no problems with Canon cameras.
Here is my serial number:  46203200XXXX
Canon S100
1. What is being done by Canon for this fix?
2. What is the estimated repairs from Canon? Or is Canon offering these repairs for free as I suspect the damages may not be related to usage.
I've been quite careful with my camera and to have the shutter problem all of a sudden came as a surprise. The length it takes to hold down the button to take a photo increases. Now it takes maybe 8-9s for the camera to take a photo!
Thanks,
Highlighted
[ Edited ]
Thank you, Tiffany!
My camera with this issue is serial # 462132000XXXX. I wonder if they are part of the same "batch".
Does a Canon rep ever look at this site? ?
Highlighted
Angela - I really hope so. I just emailed   Canon Support <CareCenter (at)cits.canon.com>
Perhaps you can write an email too if they miss out on this forum. Pretty generic email as expected.
We might as well compare notes since we're in the same boat with this *defect* of theirs.
I feel quite bad as I recommended many of my friends this Canon S100! I had no idea this problem would occur and I hope they don't have this problem... I forwarded them this thread so they are ready to write if such a problem occurs.
And I'd like to note I did try those steps to resolve the problem in the email below. It's basically a reset and no it didn't work.
Thank you for contacting Canon product support.  I understand that your PowerShot S100 camera is displaying a lens error. I will be happy to assist you with this error.
A lens error indicates that an internal error has occurred.  Sometimes this can happen if the batteries run very low while the camera attempts to power off.  It can also appear if there has been physical damage to the lens mechanism.
Note:  Please ensure you use an alternate or fully charged set of batteries to check your camera.
Please follow these steps to attempt to resolve the problem:
1.  Remove the batteries from the camera.
2.  Let the camera sit with the batteries removed for approximately 20 minutes.
3.  Reinstall the batteries and power on the camera.  If you receive the same message, your camera will require service to correct the issue.
Canon has confirmed that some PowerShot S100 digital cameras encounter a lens error caused by a disconnected part inside the camera.  Those PowerShot S100 Digital Cameras within the following serial number range are affected:
The first and second digits of the camera’s serial number are any number from “29” through “41.”
For example: “29xxxxxxxxxx”, “30xxxxxxxxxx”, ”41xxxxxxxxxx” etc.
(The [x] characters shown above represent the remaining characters of the product’s serial number.)
Canon USA will repair free of charge, regardless of the warranty status, if it is confirmed that the lens error has been caused by disconnection of the part inside the lens.  If your camera has a serial number in the range listed above you are entitled to have your camera repaired free of charge.
http://www.usa.canon.com/cusa/consumer/standard_display/consumer_repair
Please mail your camera to the Factory Service Center (FSC) shown below.  When shipping your camera, be sure to remove the memory card and battery.  You are not required to send any accessories or manuals to the FSC.  Include your name, email address, physical address, telephone number, and a letter describing the issue.  Please remember to pack the camera well to prevent damage during shipment and send it using a service that can track and insure the package.
You may send your camera to the following address:
Canon Factory Service
12022 Canon Boulevard
Newport News, VA 23606
Upon arrival at the FSC, your camera will be entered into our repair database and assigned a repair number.  A technician will visually inspect your camera and advise you of the findings.  When the repairs are complete your camera will be shipped back to you via Federal Express.  Usually, a warranty repair is completed within approximately five to seven business days of the camera's arrival at the FSC.  If the repair entails something that is not covered by the warranty, a written estimate will be emailed or mailed to the address that you have provided.  All repair work will begin once the estimate is approved and payment is made.  You can decline the repair if you wish by notifying the FSC and the camera will be returned to you.
*Please note that our U.S. Factory Service Centers are unable to accept packages from or return equipment to addresses outside the United States.
I hope this information is helpful to you. Please let us know if we can be of any further assistance with your PowerShot S100 camera. Thank you for choosing Canon.
Sincerely,
Nancy
Technical Support Representative
Highlighted
Occasional Contributor
Hi tronnebonne: Is Nancy From Canon mistaken, when she describes your camera's problem as a 'lens error'? The problem that most of us describe here (you included, I think) seems to have nothing to do with lens errors, or error messages of any kind. Or am I mistaken? I certainly never received any error messages of any kind from my camera. The thing turns on  quite happily, the lens extends and focuses...it just won't take bloody photos.
Ian
Highlighted
Re: shutter release not working S100, series 46
Yes, TronneBonne and Ian
It is a very "canned" reply. Not even specific to the S100. Considering so many clients have issues with this, you would think it deserves at least a more technical answer!
My issue is as yours - no lens error message appears. No error message at all appears. The shutter release just stops working in heat and humidity. I live in Canada, not the tropics!
powered by Lithium
