12-15-2020 03:22 AM
I bought a new Powershot G5X, inserted a 128GB sd card (also brand new) and the camera says "memory card error"
It is a cheap 20€ 128GB sd card from Transcend - Transcend Ts128Gsdc300S Sdxc Memorycard, I, C10, U3, V30, Black, 128Gb
When i put in a very old 8GB SDHC card, the camera works fine, so i think the cardreader inside the G5X isn't the problem.
Anyone else experiencing this?
12-15-2020 04:46 PM
@Boejakasja wrote:I dont want to format the card, card works perfect in laptop, other canon camera, and other devices so I assume the card itself s not the problem, i want to keep the data in the card so format is a nogo
Buy a new card, and format it in the camera. Do not use the memory card in the camera as a storage device, either.
12-15-2020 04:26 AM - edited 12-15-2020 12:18 PM
Have you low level format the card in camera?
12-15-2020 07:41 AM
The card inserted is the same card as my D1300, in the D1300 no problem, in the G5X "memory card error"
12-15-2020 12:17 PM
@Boejakasja wrote:The card inserted is the same card as my D1300, in the D1300 no problem, in the G5X "memory card error"
What about my question?
12-15-2020 04:26 PM
12-15-2020 04:46 PM
12-16-2020 01:51 AM - edited 12-16-2020 01:51 AM
There you have at least one problem.
12-16-2020 06:19 AM
12-16-2020 10:23 AM
Buy a full-size SD card and try it in the G5X, if it does not work return the new G5X for a refund, or an exchange.
