Reply
Highlighted
New Contributor
probleme batterie powershot s2 is
[ Edited ]
Hello,
I have a problem with battery on a powershot s2 is.
I puts new battery and I make 2 or 3 photos and there is a message " to changebattery ".
I use new battery or reloaded batteries but ca do not work.
Thank you for the help
Highlighted
Respected Contributor
Re: probleme batterie powershot s2 is
If you are sure the batteries are good then you have an internal problem that would cost more to fix than the camera is worth.
You can check insisde the battery box to make sure the contacts are clean.
Your model camera is available on auction sites for very inexpenive prices you should check those if you want to stay with that model.
powered by Lithium
