10-10-2014 07:19 PM
steps to set-up the front control ring on the G15 are difficult to follow in the guide. Any help would be appreciated.
10-13-2014 07:04 AM
Hi socaljd!
Thanks for posting.
When setting this up, there are a few things to know. At the top of the chart in the menu for setting up the dial is M, AV, TV, and P.
M: Manual mode
AV: Aperture Priority mode
TV: Shutter Priority mode
P: Program mode
Under each of those, you need to set which function is contolled by the dial for that mode are shooting in. There are two settings to choose from, TV: shutter speed and AV: aperture. For example, under M: Manual mode you set it to TV, the dial will control the shutter speed while you are shooting in the Manual mode.
10-13-2014 07:04 AM
Hi socaljd!
Thanks for posting.
M: Manual mode
P: Program mode
10-18-2014 09:36 AM
Thank you very much.. That explains it very well. Great camera!
socaljd
