07-15-2015 02:21 AM
07-15-2015 08:29 AM
Hi taper21!
Welcome to the Canon Community Forums and thank you for your post!
So that the Community can help you better, we will need to know exactly what Canon equipment you're using (which model printer and which model camera).
If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team by phone or email.
Thanks and have a great day!
08-07-2015 01:09 AM
I believe had answr on this before that did not help So-
I have a Canond pixmamg5600 series . mg5620.
The camera is a canon sx150is
I wouild like to know, if possable, to print directly from camera to printer--.I have usb cable if that helps.
Thanks
08-09-2015 09:43 AM
taper21,
The PIXMA MG5620 does not have a USB port on it to allow a direct camera connection. However, it does have a memory card slot in it, so you can remove the card from the camera and put it in the slot on the printer and print images directly from the printer that way.
08-09-2016 06:10 PM
i am connecting camera, which has card installed, to buss on tower in trying to dowload picture that are in camera.
08-11-2016 04:33 PM
I typed in, I think, what caused my not being able to donload from camera via cable. to computer.
i accidentely turned on computer, redone the second time which brought flg on screen a to trouble to be corrected.
since that time i havr not been able to do the above.
Is is alright to go to" back up and restore" to type in date ahead of the one with downloading problem ?
thanks
08-14-2016 01:55 PM
Where do I find answer to my question as f esterday ? If there is one.
08-13-2016 04:13 PM
I have camera power shot sx150 is connected by cable to computer buss.
turning on to download shows 1 picture that is in memory card than turns itself off altough green light showing downloading takeing place. But that does not happen as to downloading.
thanks.
taper21
