Reply
Highlighted
New Contributor
Accepted Solution
WiFi
I'm tech challenged.  It appears that the only way to save pictures to, say, a computer, is by WiFi.  I followed the instructions, but can't seem to get it going.  It's just not intuitive!!  I tried to download the software on my computer-I did not get the prompts, as I should.  I have an Apple OS Catalina v.10.15.4, but I read that the software is not compatible with it.   What's an access point?  I have a Canon Powershot SX420 IS
Highlighted
Super Contributor
Re: WiFi
What Mac do you have? Most iMacs and many laptops would have built-in SD card (memory card) readers. If so, you could remove the SD card from your camera, insert into the slot on the computer. You could then copy the photos to your computer.
Ricky
EOS 5D IV, 50mm f/1.2L, 135mm f/2 L, 600EX-RT (x6), ST-E3-RT, Vixia HF G50
Highlighted
Honored Contributor
Re: WiFi
If you don't have an SD card reader connect the camera to the computer via cable and select the Apple product Image Capture from the Application folder/list.
1D X Mark III, Rebel T5i, Many lenses, Pixma PRO-100, MX472, LR Classic
Highlighted
New Contributor
Re: WiFi
Perfect.  I did not know that there is an SD card slot on the back of my Mac!  I tried it and it worked.  So much for me relying solely on the Canon manual, for guidance - this is the solution I was hoping for!  I appreciate it!
Highlighted
New Contributor
Re: WiFi
Got it!  Thanks.
powered by Lithium
