08-12-2015 10:23 AM
Sybergoonies,
Since this only happens in low light, it is probably just a slow shutter speed being used. The longer shutter is necessary to properly expose the image in the lower lighting conditions. You may want to increase the ISO speed to compensate. Press the FUNC/SET button, select ISO, then turn the dial to choose an ISO speed. For lower lighting conditions, you will likely need to use at least ISO 800/1000 or higher.
08-12-2015 03:42 PM
08-12-2015 03:50 PM
Hi celticfiddle!
The "Accept as Solution" option is only available to the original poster of the thread, as a way for them to confirm if a posted solution has worked for them. We hope this clarifies!
08-13-2015 03:13 AM
Hi Mike,
Thanks for the further clarifications.... I will try this out and I think it should work.
Thanks again.
