07-21-2017 05:05 PM
07-21-2017 07:29 PM
Have you tried pressing the display button mulltiple times? There is a slight chance that the circuit board underneath that button is in a "stuck" state whereas the little printed circuit board switch is stuck somehow in limbo. I'm just guessing because it is part of the circuitry to steer the image. Outside of that and what you've already tried there aren't any other solutions outside of repair.
07-21-2017 07:43 PM
Hi John! Thanks for the tip. While I had tried that earlier I went abroad and did it about 20 additional times. The display toggled well between screen and viewfinder but still no live view. Also removed battery, rebooted and tried same sequence several more times. Thanks again for trying.
Stardazer
07-21-2017 08:05 PM
Ok I just looked at a service manual I have for a G11 and the troubleshooting chart for no image displayed. They list 2 possibilities the main circuit board or the LCD circuit board as the 2 possibilities. The G11 is similar in design and buttons like the display button. Both possibilities require service and parts in which case a working used or refurbished SX50 would likely cost less. I have 2 SX50's by the way and many accessories for them I like the camera.
07-21-2017 11:20 PM
