Reply
Highlighted
New Contributor
SX260
I can set my metering, but every time the camera shuts off it goes back to "evaluative".  Is there a way to lock the settings so that spot metering can stay on until I change it?
Highlighted
Valued Contributor
Re: SX260
Hi JackieL.
I have the same issue with the SX150 and the G12, although if I leave the cameras in center weighted metering, that seems to stay even after the camera is turned off and back on.At least with the G12 I have two custom setups that I can set to have my most used settings. Pretty frustrating because my old A510 holds the spot metering just fine.
If I come across a solution I'll be sure to let you know.
Smack53
Highlighted
Re: SX260
Hi JackieL,
This is normal for this camera.  The PowerShot SX260 HS does not retain the metering settings when you turn it off.
powered by Lithium
