Refurbished SX530HS dropped and hitting Lens Error
caughtoncordand
A small broken piece of plastic is visible if you look at the camera lens. As the camera is two years old it's past warranty and the cost of sending it in for repair will nearly match replacing it. Does any easy method exist for getting at the plastic that is under the first layer of glass? ( I assume a decent % chance exists that the camera won't function even if it was removed as the plastic likely served a purpose in the movement of the lens)
Additionally, am I better off using a lens cap that isn't on a cord or is on a cord of a diffrent material than the stock? The two times my camera has dropped  over the last two years have both been the cord getting caught on something and that causing the camera to get pulled from my grip. It'd be less of a loss if the cord holding the lens cap broke
Waddizzle
Those lens assemblies are put together like a Gordian Knot.  You might be able to fix it yourself if you have 4 arms and hands. I think your camera has reached the end of its' functional life.  I never use those lens caps on a string things.  I would stop using them.
1 REPLY 1
Waddizzle
